Planning a road trip and would like some charging advice
  • Thread starter Thread starter NevadaTech
  • Replies Replies 12
  • Views Views 153
NevadaTech
So I'm planning a trip between Las Vegas and Los Angeles in a couple weeks.
Currently I'm charging at home and have not needed to any other source. I charge level 1 with the 120V AC adapter. Since my average weekly travel miles are low I can plug in a few nights + set the timer for the lower charging rate. It all works fine, eventually I get up to 80% and my 'low' for the week is 50%.
The trip between cities is about 270 miles, all highway, 80 miles/hr (in real world), desert > so AC will be on. I'm not worried about charging stations, from Las Vegas to Baker is about 100miles so I'm guessing I'll top off there then recharge in LA.
Some questions
  • should I charge to 100% before I leave?
  • can you recommend a good CCS to NACS adapter?
  • if I plug into an 800V with a NACS adapter, the charger and car will negotiate that down to 400V?
One time my wife asked me why some yahoo was bouncing his car up and down while filling it with gas. I explained that he's trying to put more gas in by filling the voids/spaces in the gas tank that are left for gasoline/gas to expand. Generally, this is a bad idea unless he is immediately driving a long trip, and I mean immediately. With similar logic, is this when I should be charging my Kona to 90-100%? I'm using the juice immediately. Is my understanding that 'storing' the energy is not an issue, the concern is maxing the range of the battery/cells capabilities during charging is?
Yes, charge to 100%. This is the time to do it.
The car handles all the negotiations with the charger, so as long as the connection is good (and you can arrange payment), everything will work out.
As for an adapter, I don't have one presently, but make sure that you get the correct adapter direction. For my Kona electric, I'd need a NACS-to-CCS adapter. Also, note that there are separate adapters for DC and AC charging. Cars with NACS ports are smart enough to figure out whether they're connected to AC or DC, but these adapters are just simple devices with no smarts beyond temperature sensors.
I'd also suggest doing a test with a local DC fast charger. (the cables are much bigger, so get experience handling them and you want to shake out any car problems before you're on the road). If you've already picked out a likely few charging stations, preload the apps at home and maybe use one of those for your pre-test.
Also, don't forget the battery pre-conditioning. Probably will be cooling in your case, but proper temperature ensures better DC charging.
And note that while DC charging, the charging rate will drop dramatically when you pass 80% SoC. I don't remember details for Kona, but I remember someone doing a test with an Ioniq 5 and getting the advertised 10-80% in 18 minutes, but then taking another 45 minutes from 80% to 100%.
I use plugshare on the day of travel to checkout all possible chargers that i may use...usually if things are not working or under maintenance ..plugshare is good about this ///that is when i can change my plan of where to charge. Also the plugshare score gives you an idea if people struggled to charge or not there.
Based on what BobNY13 said, before you go AC charge to 100% at home.
Then DC charge to only 80% on the road.
Yeah, but I would still set my DC charging limit to 100%. At one stop, there was a line for the fast chargers, so my wife went into the mall. After I connected, I joined her there and by the time we were done the car was at 95% even though we intended to leave when it hit 80%. We were immediately back on the highway, so I wasn't concerned at all of having a high SoC. But having the extra buffer was nice
@NevadaTech , I agree with all the above comments, especially from @BobNY13 . Which year Kona Electric did you end up buying? If you bought it used, you did already change the GRU oil, right?
I'll add emphasis to having NACS->CCS adapters as I've found Tesla Superchargers extremely reliable and almost always available across the country. For adapters, I've successfully used Hyundai's, Lectron, and A2Z on my 2020 Kona Ultimate. When trip planning, be sure to look for and select Tesla Superchargers which are CCS compatible (use the Tesla app or Tesla website to determine that). For hotel charging, a Tesla -> J1772 adapter is also a very good idea.
Do you have a collection of accounts with the more-popular charging networks (e.g., ChargePoint, Electrify America, etc.)? This speeds up connecting and makes opportunity-charging easy whenever one stops while on the road. I actually prefer not to use dcfc if I don't need to.
When looking at PlugShare for possible charging spots, look not only at the "PlugScore" but also read the latest comments as corrections to the charging station problems may have already been implemented.
Oh, and don't forget to carry a portable EVSE and extension cord and a handful of NEMA adapters as one occasionally can get into trouble out in the boonies (not on the Las Vegas <-> Los Angeles run), where campgrounds and welding shops and marinas can save the day. Don't be afraid to ask a hotel or friends you might be staying with if you can plug into one of their external outlets as overnight slow charging is IMO always preferable to dcfc. Of course, offer to pay.
Trip planning is kinda fun as the name of the game is to never ever wait for the car to charge but to always plan on doing something else. After all, we never wait for our cellphone to charge, do we?
Bon voyage!
One more thing: high speed is, by far, the greatest range killer due to the non-linear aerodynamic drag. Yes, the LV<->LA excursion is boring, but do pay attention to your "miles to destination" vs. your "range remaining". I keep a mental buffer of either a fixed ratio or number of miles between the two and try not to end up at the next charging spot with less than 10% SoC. If in doubt, SLOW DOWN (and stay in the right lane). You'll be amazed at how far the Kona can go when featherfooting at 50 mph (in the slow lane!). Following a semi or large RV works wonders at improving the car's mileage (fuel consumption)..Oh, and you might consider pumping up the tires to at least 40psi.
@NevadaTech , do let us know how the trip went.
Start %Start Milesmiles shown
Lotto Trip6421266178
next5421295148
stop then return3821322102
end of mountains342133291
top of Railroad Pass172136433
highway exit132137626
home122137824
Last week I performed a 'test run'. From Vegas into AZ to buy some lotto tickets. The Start% shows my battery level. Miles Shown = what the range estimate is. Those familiar with the AZ to NV drive will remember the 10miles of mountains right around the dam. Overall it took 52% battery to do 110 miles. Early into the drive I had to turn off the AC.
I had planned to test charging at the lotto/gas station. They have a Blink CCS charger there. I'll update the charging in Plugshare. That charging stop didn't work, all my fault. I plugged in and walked away. Twenty minutes later I checked on it and realized my settings were still in after-hours/cheap charge time only. Dang it. Nothing horrible and I'd rather learn my lesson there versus checking on it after after an hour of no-charge while I'm also pressed for time.
Tomorrow I'll head out for LA. Since then I have purchased an A2Z NACS to CCS adapter. They have a newer model out that addresses the wonky under clip/switch. It's a much more direct plug-in adapter now with a simple latch on top. Just FYI, it appears Kona's (and most CCS?) can only use Telsa Supercharger v3 stations. The v3 means the charging unit can adapt to different voltages for different cars, whereas the v1-v2 always expect Tesla voltages.
While westbound, the Vegas to Baker leg will be the hardest (20miles of mountains and high speeds), it's only 100 miles and I expect to charge there. A full charge there, then a ton of re-charge going down Cajon Junction, the last third of the trip will be much slower saving juice. It's a mix old and new tech, driving my fancy new electric car to a Commodore retro (1990's PCs) show in Burbank.
Great to see you had a successful-enough test run. Definitely put in updates in plugshare. I use it to plan, so seeing that people successfully charged recently is a great help, especially if there is a choice of locations or if the location is out-of-the-way.
Table doesn't work for my browser.
@NevadaTech, thanks for the table.
If you like playing with numbers, you could expand your spreadsheet by converting the battery percentage to kWh (100%=64kWh, if we believe that's the usable capacity) and show your energy consumption in terms of Wh/mile (traditional), or, as Hyundai does it, miles/kWh, for each leg.
EPA says we can go 258 miles on our 64kWh battery, yielding 248 Wh/mile or 4.03miles/kWh.
For your 112-mile trip I came up with an overall 52% used (33.3kWh) yielding 297Wh/mile or 3.37 miles/kWh. Considering this was a two-way average, you probably were not driving 50mph ;). Incidentally, with an electric car one usually recoups a good percentage of the energy lost while climbing (70%?) on two-way trips over the same course.
Oh, and don't confuse the instrument panel miles/kWh reading with the 'true' consumption, as that shows battery->wheels and not wall->wheels.
Wishing you a safe LV<-->LA trip.
I did a road trip back in September from Hagerman, Idaho to Salt Lake City, Utah. It was about 250 miles overall. I only had to stop ONCE about midway through the trip. Started out of course at 100% and charged back up to 90% at that midway point at a new Pilot Truck Stop charging station which was nice to have right there. It only generated 60kw for me although it had 350kw capacity (would have been nice to have a Ioniq 5 with its 800volt architecture). I only spent enough time there to have my wife and I go into the convenience store and take care of business and come back for a little rest and we were on our way. The following day at a Walmart in SLC charged back to 100% as I arrived with 30% which was nice. I did some rough estimations that every 10% you charge gives 25 miles. That's pretty close. Indeed once I hit 85-90% things do indeed slow considerably. My lease is up in October and I'll probably switch to a 2026 Ioniq 5 SEL. We shall see. The Subaru Solterra Limited XT is pretty interesting as well, but doesn't have the 800 volt architecture so who knows what I'll select. The price will likely be much better on the Hyundai as it always has been. Probably about $3000 down and $379 a month. The Solterra is over $400 a month. As far as travels I rely almost exclusively on Plugshare to make my charge decision. ABRP is another app but is a bit of a pain in the arse to manipulate some parameters with so I don't bother with it.
