David Towle
I did an inadvertent experiment on my Clarity. There was a lot of rain last night, probably with some salt on the roads, so my brake discs must have started out pretty rusty today. I pulled out unusually with the radio off, and made my first (very gentle) stop with just the brake pedal, not the paddles, and heard a lot of graunching /grinding noise. I made the next stop with the paddles and of course there was silence. At that point I realized the difference, so made a third gentle stop with the brakes and there was more of the grinding noise but not so loud as some of the rust got removed.
So I now believe that when you use the brake pedal you are getting a combination of regen and real braking from the start of pedal travel. I don't know how the brakes could work smoothly anyway if that didn't happen. Some on this list have thought the brake pedal was just regen initially but I now don't think that is the case.
I will try to repeat this test after future rain/snowstorms to verify it happens again, and I hope others will too.
