Sweet, another Kona Electric in MA. Congratulations! Mine is the same color and trim, but 2019.
I'm jealous! That's the color I wanted, but when I was buying (early March) no dealer in northern California had one!
Congratulations Clamps! Did you find an in-state dealer that had 2020s on the lot? Back in January I couldn't find a single New England dealer who even anticipated getting an allotment of 2020 Konas until maybe late spring, they said. I ended up going to a Maryland dealer back then.
Bulgogi, interesting name. Great color!
If you google EVSE, there are a lot of choices available on Amazon. No need for an expensive wall mounted charger with wifi. You can can manage all your charging from your car (incl thru bluelink). What I would recommend is to install a 14-50 240V receptacle in your garage and then buy a portable EVSE that can be taken with you on trips. Be sure to get one that also can charge with 110V (most can) so you can also use an RV adapter at campgrounds. And easy to build your own.By the way, anyone reading this post. What home EVSE, charging box, would you recommend for a Kona? I was looking at Chargepoint, Clipper Creek and Juice Box.
A few days ago I wrote this same question in the General area of the forum. I wasn't sure then which car I would be buying and I don't know if it would make a difference. Maybe I should add that detail to the thread over there.
Ceramic Blue is the way to go!! Congrats!!I've been added to the collective. My wife has named her Bulgogi.
I'm sure I will have even more questions as time marches on.
That was my first pick as well. Afterwards it was either red or white but I couldn't find any red in my area in any of the trim levels. Gobs of silver and black.
Congrats and welcome, fellow New Englander.I've been added to the collective. My wife has named her Bulgogi.
