So the port( Canadian version) is located under the dash below the fuse panel (above the hood release) unlike the reports from UK(one person is producing a fuse cover with a hole to accommodate.
This make it SUPER easy to run an OBD extension cable c/w 90 under the dash supported by existing wire harnesses and exit under the steering wheel (attach the reader w/velcro).
Still have to download Torque pro and pertinent files, (later)
Link to cable
https://www.amazon.ca/dp/B00J2N0VG4...3&creativeASIN=B00J2N0VG4&tag=shopbotca-20ext
Link to reader has been discontinued (v1.5)
https://www.ebay.ca/itm/Mini-OBD2-E...an-Tool-OBD-II-/153262963680?oid=111329509215
I think v2 has auto shutoff mine has a power switch, safer to have an in line power switch on the cable itself if using a reader without one.
Link to cable
