Number of Kona dimple depressions
electriceddy
Moderator
278 total on the front end.
Starting at the top part, 7 rows horizontal in groups of 12,16,14,19,16,19 and 16. (112)
The lower section has 4 groups of 18/19 alternately with the last row at the bottom 18 (166)
As a bonus I will throw in the wheels
5 "spokes" with 20 dimples in each group totaling 100 per wheel.
So a grand total of 678
If it's any consolation, 64 of the 278 front end dimples are hidden behind the license plate, so one only needs to clean the drying wax (or bugs) out of 214 of them.
I know, waxing the car is pretty boring so I needed some entertainment:D
No license plate on the front here in Nevada, so all dimples need to be cleaned here.
No bugs in Kitslano neighbourhood of Vancouver---salt air kills 'em all if you're close to the water. Dirty Dimple disease? Okay, maybe a few bugs. Blast the bow with high pressure in the hose!
You're officially our OCD member of honour!
First waxing since last fall and those dimples are hard as ever to get the wax out.:eek:
The touch up pen the dealer gave me when I bought the car got a good workout too.
I will say this however, the dimples do a great job of hiding misc rock dings, the few that are on the smooth part of the nose are still somewhat noticeable but better than before.
The wax I use is Mothers Brazilian Carnauba cleaner wax:
https://www.canadiantire.ca/en/pdp/mothers-brazilian-carnauba-cleaner-wax-liquid-0392868p.html#srp
and this product works great on the unpainted black (and silver) trim parts
https://www.canadiantire.ca/en/pdp/silverwax-unpainted-mouldings-restorer-0396002p.html
I never wash my cars nor do I wax them. Wax is something that you only need if your car spends a lot of it's life exposed to UV rays.. The only time that my car gets UV rays is while I'm driving and occasionally if I go out for lunch.. Car is in the garage most of the time, at home and at work (not sure when I'm going to be working at the office again... have been working remotely since March). I use Meguiars Quick Detailer. Works great on every exterior surface and is great to get the bugs off..
I mostly do it to protect the paint from bird droppings, added advantage is the bugs slide right off. Doesn't do much to avoid rock dings though.
I do have a carport that is exposed to partial sun so UV protection helps as well.
Thought I would bump this thread with this new and intriguing information:
Why are there only 16 vertical lines of dimples on the top grid converging into 18 on the bottom and yet remain symmetrical?
The mystery is now solved, as the bottom 5th vertical line in on each side aligns with the top indentations of the charge port (hinge side) cover and its counterpart on the opposite side.
I also discovered (as a bonus), my 2021 models front count now stands @ 279 as there is a 3/16 inch circular one at located in the center of the bottom row of vertical dimples. (yes it is painted, not a rock chip).
Not sure why...maybe a good battery marker?:D
Hot day, cold beer, no where to go...what can I say?
I would say you need a hobby but it appears you have one! ;)
