Source: https://www.researchgate.net/public...arison_of_Commercial_18650_to_the_21700_Cells
Rivian claims they can cool the cells by one end more efficiently than Tesla's coolant channel that passes between the cells. Thermal cooling is engineering 'black magic' so I don't have a strong opinion one way or the other. However, I've wondered for a long time if heat-pipe technology could be used in pack construction.
A heat pipe uses the phase change from liquid-to-gas to transport heat away from the hot side. Then the cold side condenses the gas back to a liquid which via capillary action returns to the hot side. No pumps or cooling channels needed as the porous mat covering the hot side handles liquid transport. A whisker fuse coated with an impervious coating would be needed for cell-to-buss. The module/pack would need to be gas and pressure tight.
- The energy content per cell can be higher by ~50% from 21700 compared to 18650. Therefore, for certain applications, less cells have to be built and used to deliver the same amount of energy.
- The higher energy content on cell level leads to potentially lower effort and costs in the production of 21700 compared to 18650 type cells and their packs. ...
