Thanks for the reassurance. It's good to hear what I suspected that this was a well engineered EV. What is "Hilltop reserve"? I can't find any mention of it in the owner's manual.
See discussion here:
http://gm-volt.com/forum/showthread.php?266929-Bolt-EV-Hill-Top-Reserve-charge-setting
Quoting from the OP in that thread:
One of the concerns we've heard expressed by some is the initial disabling of regenerative braking immediately after charging, when the owner lives (or charges) at near the top of steep grade.
Since with a fully charged battery there is no place to store the energy, the only option either to permit the system to brake the car using hydraulic/friction brakes, OR to manually stop charging so as to leave some room for the energy produced by regen during that initial descent.
Well the Bolt employs a a charging system feature that looks to mitigate this occurrence.
Hill-Top Reserve , when engaged in charging options and will automatically stop the charge slightly short of a full charge so that regen will be immediately available.
This feature also integrates with the Location Based Charging feature, allowing the system to be configured so it is enabled when at home (On - Home Only) or away (On - Away Only)
Seems to have questionable usefullness, to me. You shouldn't be charging to full capacity unless you're planning on a long trip; certainly you shouldn't be charging to 100% on an everyday or every week basis.
Everyday charging should attempt to balance an everyday charge around the 50% charge level. That is, an EV driver should attempt to charge the car to a level above the 50% mark when he starts the day, equal to the level below the 50% mark at the end.
For example, if you use 40% of the battery pack's capacity in a day's driving, then you should charge to (50+20=) 70%, and hopefully when you return home you will have discharged to (50-20=) 30%. Similarly, if you typically use let's say 55% of the battery pack's capacity in a day, then ideally you should charge to (50+22.5=) 72.5% and discharge to 27.5%... altho I doubt most EVs will allow such an exact control over the charge level.
If the hilltop reserve stops the charging only slightly short of a full charge, then it seems to me this would only be of use when you were planning a road trip or otherwise were planning on a trip that challenges the EV's maximum range before recharging,
and you were starting out that drive with a long downhill run.
Otherwise, just set the charging level somewhat below 100%, for improved long-term battery life.
