Fast Eddie B
Right now, our charging needs are well met by Honda’s supplied Level 1 charger. In about 6 months, we’ve not yet had an occasion where anything other than overnight charging was required. If worse comes to worse, running on gas for a short time is not the end of the world. But rising gas prices in the future, or changing use cases, could eventually prompt a move to Level 2.
At our TN hangar home, it’s convenient that we have 240v/30A service running to our hangar door. That service is two “hots” and a ground, no neutral. At the yellow arrow:
I wanted to have a way to open the hangar door in the event of a power failure. I envisioned a transfer switch of some sorts, but a friend suggested installing an outlet, then just plugging the hangar door into a 240v generator if we need to open or close it with the power off. So I installed a locking generator receptacle:
(I’m aware this installation might not meet code without a neutral, but none is required for this installation.)
I wired this up a few days ago and it works fine:
My plan is to start saving up for the 10,000w generator the door manufacturer says I’ll need, so as to have it by next winter. Power goes out and I need to open the door, just unplug from the outlet and plug into the generator.
That outlet is in a convenient spot to charge the Clarity either inside or out. I don’t see any reason I couldn’t use this same outlet to charge the Clarity, if and when I get a Level 2 charger. Via an adapter like this:
Of course, with the Clarity charging there will be no door opening, and vice versa - but I don’t see that as a problem.
I know just enough about electricity to be dangerous. But does anyone see any flaw in this plan?
