KonaTom
I remember a post where someone mentioned that switching between regen and motor has efficiency loses, and that made sense. I started to pay attention lately on how often regen kicked in during a normal drive, and it was a lot. Maybe it was because my foot control is not as good as others, but I found it difficult to get the car into no regen frequently, especially in city traffic.
So, I tried setting the regen level to 0 using the paddle, but keeping auto/smart regen on. It takes a bit of time to get used to the car cruising when you take your foot off the go pedal, but it was a much smoother drive, and more comfortable for passengers. The smart regen slows you down when approaching other vehicles, and if need be, you can then touch the brake to slow even more, adding more regen.
Using this system, you control when regeneration comes on, and it comes on much less than using any other regen level. That would seem to be more efficient. It’s true that you need to touch the brake pedal more often, but you touch the accelerator pedal less.
I don’t have the equipment or expertise to measure efficiencies, but I would like to hear from someone that can, and I bet it is more efficient with 0 regen over other levels, in spite of the fact that the manufacturers and others recommend one pedal driving for efficiency. I don’t believe it anymore.
Hyundai doesn’t even allow us to set 0 regen as a standard setting, but I wish I could.
I bet this will generate some discussions!!!
