Lucid Air Instrument Cluster – Pinout / Bench Test Info?
quantityofwars
I’m working on a custom project using a Lucid Air instrument cluster and trying to figure out what’s needed to get it running outside of the vehicle.
I don’t have factory documentation, so I’m trying to map things out from scratch.
From what I can tell so far, it looks like the unit likely uses:
  • 12V power + ground
  • Some form of CAN communication
  • Possibly LVDS or similar video interface internally
What I’m trying to figure out:
  1. Pinout/connector info
    • Has anyone seen or documented the wiring for this cluster?
  2. Power-up behavior
    • Will the display turn on with just power, or does it require CAN messages to wake?
  3. CAN requirements
    • Is it expecting data from a gateway/BCM, or has anyone successfully spoofed basic messages to bring it to life?
  4. Display input (LVDS or otherwise)
    • Is the video generated internally, or driven externally from another module?
I’m planning to bench test it with a microcontroller (likely generating CAN traffic), so any insight, photos, or even partial info would be a huge help.
Appreciate anything you’ve got
