Arctiic
I've seen a wide range of posts related to this topic, which makes it really difficult to narrow down relevant information that is applicable to my case. I'm hoping to get a more definitive answer by posting here, because the noise is getting out of hand. Here are the details:
What type of noise?
A loud, consistent whirring (presumably from the two condenser cooling fans).
When does it occur?
Basically anytime the A/C is turned on and active (does not occur when air flow is on and A/C is off, etc.); also, not sure whether it's related or not, but I believe when the gas engine kicks on (i.e., lithium ion battery is depleted) the noise level has also gotten notably louder.
How loud is it?
Loud enough that I can't park at the curb in a residential at night and have the A/C running unless I want to receive complaints about keeping people up.
What has been done about it?
At first I took it to the dealership to get it diagnosed. Long story short, they took my car to the back and had me wait all day in a crammed packed waiting area for an entire day, then charged me a $75 "diagnostics fee" despite "not being able to determine any cause", only for me to drive back home that evening to discover they never even popped the hood.
I've tentatively tried a few things on my own, such as applying some nano-tape/kinetically insulating materials in places I felt could vibrate — or amplify/exacerbate them — such as the areas where (not sure what the correct vernacular terms are here) the condenser assembly is seated/bolted onto the chassis. I've also gone through and made sure all bolts were tightened. I tried cleaning the fans themselves, but very little was actually accessible to me as I didn't want to disassemble or damage anything without being certain I knew what I was doing. I've also conditioned the rubber gaskets with petroleum jelly or silicone lubricant on a regular basis, and added a rubber "lip" to the hood which keeps it pretty well sealed when closed.
I'm unsure which of the above had the most effect, but the steps did appear to abate the noise level for a while. Unfortunately, over time the noise has increasingly gotten to a point where it's no longer tolerable once again.
What I'd like to find out?
If possible, I'd like to know the root cause for this and — hopefully — do something to address it. If at all possible, I'd like to not be told that the only thing to do is to replace it altogether, especially not by someone who cannot even state with any specificity what is wrong with the assembly to begin with that's causing the noise.
What type of noise?
When does it occur?
How loud is it?
