Lock Cylinder Replacement
  • Thread starter Thread starter lincomatic
  • Replies Replies 21
  • Views Views 9K
Does anyone know if the trunk release key is actually a key or will work with any key shaped object (i.e. accord key)or it has to be the same key as the door?
It's an actual lock, same bitting as the door lock. The 06350-TRT-A51 kit contains both cylinders.
I actually did also order 04921-trt-a01... that was the correct cylinder, but had a "normal" key with it... not the type that slides into the remote, and also didn't contain the cylinder for the back seat.
