I have a 2024 EV6 and ChargePoint flex charger with 48amp capacity (#8 wire, 200a main). I charge when below 50% between midnight and 5am. Sometimes the charge rate stays at 48a/11kw throughout the charge. Other times it drops to 7.4kw after 40 minutes or so. Sometimes drops again. I have seen with dip for a few minutes and then climb back up.
The voltage at the charger and service entrance does drop from 240 by a few volts, but not much unless I run AC, Electric dryer, electric oven, bath heaters and toaster oven. Even then it is around 234 volts.
A big problem for me is that I have not yet found documentation that explains under what conditions the EV6, ChargePoint, or perhaps my utility throttles the charging rate. I don’t know if there is a problem nor what component is to blame.
