We are seeing significant price reductions in adult capable, electric scooters:
This one used to be closer to $600. Between Amazon points and a $30 discount code, I ordered one for $156:
The operational scenario: drive to work and unload what is needed. Then drive a couple of miles away to free charger(s) and use the scooter to return. I already have the helmet, safety goggles, knee pads, and will add a yellow, rain suit.
ps. For the athletically inclined, there are kick scooters for ~$100.
- Battery: 18650 Li-ion Battery Pack
- Max. Mileage: 30 KM (18 mi. Depends on Road and Driver Weight)
- Max. Speed: 25km/h (15 mph)
- Max. Load: 120KG (264 lbs)
- Light: Front Lamp, Tail Light
- Permissible Gradient(Depends on Your Weight): 15 degree
- Battery Capacity: 6AH
- Battery Voltage: 36V
- Motor Type: Brush-less DC Motor
- Motor Rated Power: 350W (0.47 hp)
- Max. Motor Rotate Speed: 700R/Min
- Motor Rated Voltage: 36V
- Max. Torque: 13.3N.M
- Charging Time: 4H
- Waterproof: IP54
- Climbing Gradient: 15 Degree
- Wheel Size: 8 inch Solid Rear Anti-Skid Tire
- Braking Distance: 4M
- Weight & Dimensions
- Product Weight: 11kg (24 lbs)
- Package Weight: 15kg
- Product Dimensions: 1050 x 450 x 930/1070/1160mm(Unfold)
- Folding Size: 960 x 210 x 330mm
- Package Dimensions: 1030 x 210 x 405mm
- Package Contents
- 1 x Folding Eletric Scooter
- 1 x Charger
- 1 x Adapter
- 1 x User Manual
