ron in new mexico
Hi, just wanted to give a few general observations from a new purchase with about a thousand miles on it. These comments are not in any manner technical, just personal in nature.
Range, as I live at altitude and the temps at night, which is when I charge, have never been close to 32F, most commonly about 15F or so, or lower, it averages only a max of 24 miles. I expect that is directly related to the charging temperatures.
But the range seems much longer than that listed in the actual. Part of this is my first drive to town is almost all, in the first seven miles, downhill. I will loose zero miles of charge in the first seven. However to the inverse I seem to loose more than seven in the uphill on the way home. So the range thing is a bit as to application.
If I use sport mode it seems to charge up pretty rapidly. So if I want to charge it up I simply put it in sport mode when in town. Seems for every three in sport I get one in charge.
Changed out the tires and wheels after a week or so, to snows. Seems mileage is about the same. The mileage now averages between in composite about 70-80 by gage.
I have a thing about warming up combustion engines, especially when new, so I do indeed start it and run the heater to run the combustion engine every day I use it. The interior heater only runs off the combustion engine. But it only heats a bit, about one of ten pegs. With a full running engine it runs about in the middle or five. I will also move it to sport when I run out of charge to see to it the engine spends at least five minutes or so at regular operating temp. It will slip in and out of EV more when not in sport mode.
So I am really not running the car for full efficiency. Come summer I will run it initially all electric.
Electricity is cheap here, but am awaiting my first bill to see the increase. Gas wise thousand miles I filled it up once, and the gage is almost full right now. Seven gallons or so was the fill up with now probably three more used, for a thousand miles.
I am starting to have to make a effort to keep it in sport mode to break in the engine. The 600 mile break in does not really apply as that is a standard number for non PHEV vehicles. The gas engine is simply not on for three quarters of the time. So a thousand is equal to maybe 200, 300 at best.
I don't want to drive to aggressively till I meet 600 gas miles on the engine. So being cautious that will probably be in 3000 miles.
I will have to change the oil more often as with such infrequent use and sporadic use it probably approximates severe service.
Car handles on the winding mountain roads better than my crosstrek,which is a surprise considering the small tires on the PHEV. I stayed with the same size for the snows. Went to continental as opposed to Michelin snows I had on the crosstrek.
Lane assist could be stronger by my take. Blind spot and all that works just fine.
Back up alarm went on for a pedestrian who I just did not see, it being twilight, so that helps a lot.
Crosstrek hybrid averaged about 36 or so. Seems Kia the mileage by my read it is between by gage 70-80, and by the actual gas use, probably closer to 100 in gas use only considered. The 20 or so variance would probably be the electric composite of the total. In any event I would anticipate for most very little gas is used If you drive about twice the EV range as I do.
No warm up, no sport mode, and all the rest I could get probably very much more out of the charges.
Maybe when I see the electric bill I will conserve more
Not much snow use yet. Just on the driveway seems OK.
All in all, how will I ever use up my smiths grocery gas credits with this car.....seems unlikely I will. It uses so little of it.
All in all then, nothing to complain about. AV all that seems OK. Maps used it with my phone, all seems good. Mostly I just use the music which for some reason now has better range(mountains obstruct the signal) I will try to find some thing, I expect I just must try harder
Takes a while to charge up....
