I just posted a comment on a spare tire for the Kona Ev. I will be picking up a new Kona in the next week or two but have been doing some research on spare tires for some time. The Soul Ev, Niro Ev and Kona Ev all come with 215 55 17 tires. The non ev version of these cars will fit a 16 inch donut but apparently a 16 inch wheel will not clear the rear brakes due to the cars having an e brake. 16 inch apparently fits on the front only. I have also found that both Kia and Hyundai have the same wheel center hole at 67.1, lug spacing 5x114.3, and lug size M12x1.5. I have seen on other websites that a kia sportage wheel will fit. 17 inch. From what I can tell the best size tire to match the stock tires would be T135 80 17. I think if you order the tire at the same time for the sportage they will mount a T135 90 17. This will not be off by to much. The part number I got from the kia dealership is D9F40-Ak900 for the wheel kit without the tire. In my post I asked if anyone on this forum has done this but have not heard yet. I'm probably going to proceed in this fashion myself.Just got my 2020 EV EX a week ago and so far I love it. I didn't realize the car came without a spare so I am on the hunt for one.
I did see one at KIASTUFF.COM but I'm looking for other suggestions from owners here in the US.
Thanks in advance.
You might want to see this thread.
https://www.insideevsforum.com/community/index.php?threads/kia-niro-ev-spare-tire-kit.6356/
I also thought I saw one someplace that actually pointed to parts you could order online.
Thank you.16” fits the boot well and the large fixing screw perfectly holds it in place. It does not fit the rear hub, just fouling the calliper a little.
Puncture in the front, use the doughnut.
Puncture in the rear, fit the doughnut to the front then use the good front to replace the punctured rear.
Punctures don’t happen that often to worry about the extra effort.
The Niro manual says nothing about this. It just says replace the flat tire with the emergency spare tire.Isn't one supposed to use the good wheel in the front because that is where the drive is and also because front is where we steer?
Just an update......
This applies to the Niro EV, Soul Ev and Kona Ev. I received the 17" compact wheel and test fitted it on my 2021 Kona Ev. It clears the rear brake caliper just fine. I have now ordered a 135/90 R17 tire. This route was more expensive than used from a junkyard but unfortunately I was not able to locate a used kia/hyundai 17x4 compact wheel and/or tire combo in Western Canada.
This route was a less expensive option than ordering the kia 17" spare tire kit for the 2017-2021 Sportage (D9F40-AK900) or the kit for the Niro/Soul/Kona EV from Modern Spare.
The wheel was purchased from a Hyundai dealer as fitting a 2018-2020 Hyundai Tucson. Part number 52910-C1930.
