I'd be interested in seeing some photos showing the size relative to other vehicles. The dimensions read like it's quite large, but photos make it look VW Golf sized. Real life range info and charging info would also be helpful
So I'm hoping the VW T-Roc is sold Worldwide so you can use it as a guide - (And as you can see, I parked far better than the T-Roc)
If not T-Roc
Dimensions: 4,234 mm L x 1,819 mm W x 1,573 mm H
Whereas I5 Dimensions: 4,635 mm L x 1,890 mm W x 1,605 mm H (Much Bigger)
Only charged twice so far, & when I drove back from the dealers it gave an estimated range of around 270 miles @ 99% charge. You can see that 2 weeks later from the above graph that it gave a range of 193 miles when at 71% - which also extrapolates to a 270 mile full charge range (193/71) x 100 = 271
Thank you for the info and looking forward to more details. In what country are you located and which battery size do you have? Have you tried exporting power to run anything? In the USA I believe power export is limited to 1.9 kW but almost double that in other countries. Same with towing capacity. In USA it’s limited to 1500#.
Shropshire sits in the middle of the UK, & like all the other I5s in Europe, the largest battery we have is 73kW.
Not tried out the V2L yet & towing capacity is 1600Kg - thought that would be the same in all markets.
Q./ What weight measurement does a # indicate - I've never come across that one?
