Interconnected charging networks
  • Thread starter Thread starter Esprit1st
  • Replies Replies 4
Esprit1st
I accidently found out today that EVGo and Chargepoint are working together and you don't need two accounts.
I ordered a Chargepoint card because my new cellphone doesn't have NFC (who would have thought [emoji33]) and I tried to use it today on a free level 2 charger. Since I have the card (EVGo and blink as well) in my wallet I just held my wallet against the charger to initiate the charge.
It worked and initialized and started charging.
After a while I decided to check the so and I didn't see my car charging in the Chargepoint app. But it showed charging in the Hyundai app. Just because I opened the other apps and the EVGo so showed my car charging.
So apparently the charger recognized my EVGo card instead of my Chargepoint app ... [emoji23][emoji106]
Sent from my moto g(7) using Tapatalk
I thought *EA* and Chargepoint were working on a cross-authorization
partnership. Well, maybe both are true and it's the leading edge of
only needing one cred to start a charge anywhere.
I suppose ultimately the right answer is plug-n-charge and having the
VINs on file, but that might get interesting in some situations like rentals.
_H*
As a fellow geek,how can you forget having NFC in specs;) This is good news,there really needs to be more charger integration,and availability status on a network.Check-in in plugshare's not ideal if you're in a sketchy area,and could get robbed.
ChargePoint is doing a good job at becoming the principal aggregator of EV charge authentication. I discovered a couple weeks ago that I could use my ChargePoint account at EVgo.
If you look at the filters available in the ChargePoint app, you’ll see they have the following networks integrated so far:
  • Blink
  • SemaCharge
  • EVgo
  • Flo
  • Greenlots
I’m sure EA will eventually show up too once they finish testing interoperability. I really like the idea of being able to use 1 card or app with any charging network.
I know! Can't believe I missed that, either. [emoji2957]
  • Blink
  • SemaCharge
  • EVgo
  • Flo
  • Greenlots
I like it too. Their so is really good too, showing you the current charging speed. I haven't used it in a non-chargepoint charger yet, so not sure if it will show you the speed of out of network chargers.
