RobinBrain
What MPG do you guys get when the engine is running? Looking at the instant mpg I get around 43ish at 65 MPH. So just engine not engine and battery combined
Set the center screen to powerflow and you'll see how everything works while in action.
FWIW the car is ALWAYS engine and battery combined, or battery only. There is simply no such thing as driving the Clarity only on engine. Lack of transmission prevents this opportunity. The engine is a generator. So even while cruising with engine running and in gear mode which is the only time the engine is providing SOME power to the wheels, the battery is almost always either expending or receiving energy, depending on the instantaneous load...
And yet I have seen the energy flow display show energy coming only from the engine, with no flow line between the center and the battery/traction motor at the bottom. In this configuration, the gear icon is present indicating the engine is connected directly to the wheels. It's challenging to photograph it since it's transient and I'm driving at highway speeds when it happens.
Thats what i see also. Do you remember what the instant mpg is at those times?
Agreed that happens. But the engine is not the exclusive power source to the wheels at this time.
When this happens it is the moment the engine is indeed coupled to the front wheels, but the engine is also spinning and operating as a low speed generator at the same time, providing an electrical charge into the battery at the same pace the electric traction motor is putting electrical power out to the wheels.
indeed. It does all those things in gear mode depending on load at a given time due to wind, hills, etc. That better illustrates my point that just because the engine is coupled, doesn’t mean the electric motor isn’t also providing supplemental power to the wheels in addition to the engine...sometimes more and sometimes less.
So even during those times where you see the flow chart balanced out, both the engine AND the electric motor are providing power to the wheels...the car is still not being propelled by only the engine...
At least that’s my understanding of how this car works. As always, I could be wrong...
It totally depends if you are going uphill, downhill, upwind, downwind, how heavily loaded, whether gear mode is engaged or not, what the outside temp is and what state of charge the battery is in. Instant MPG reading changes with varying RPMS of the engine, which go up and down with battery drain needs, it does not stay linear with any particular speed. On long road trips I've seen as low as 20 mpg and as high as 65 mpg. It's usually near the 40-ish range, but walks around, at 70 to 75 mph.
Does the clutch actually disengage with the brake?The traction motor/generator is connected to the front wheels with a couple of gears and is always turning when the wheels are turning. The motor/generator you call the starter-generator is connected directly to the ICE and is only turning when the ICE is turning. If the clutch is engaged and you step on the brake to slow the car, the clutch will disengage, so the braking resistance and regenerative braking is only from the traction motor.
@craze1carsAnd while I’m asking, does braking resistance and subsequent regen power to the battery come from the traction motor or the starter-generator? Would that depend on whether the clutch is between the motor and s-gen or between the s-gen and engine. I can’t find @insightman,s and @AnthonyW’s diagrams.
Inquiring minds want to know!
