Screen shots from the Munro video, this traction battery is awesome. I had my doubts about the cylindrical cells, 2170, because the shells add weight but no energy. The volume efficiency, the amount of battery chemicals to shell overhead increases with size. Large format, cells are attractive for energy density until factoring in the mechanical structure needed. In contrast, this collection of cells makes a very strong, stiff structure.
Notice the assembly is potted with an silicon compound making is both sound deadening and stronger.
The bus bars are on the top so all of the cells are oriented the same way which simplifies automated assembly. The external 'whiskers' are spot welded to the bus bars which are layered on top:
All of the cells are in parallel which helps to keep them balanced. Now the real question is whether the 'whiskers' also work as a fuse. When a cell internally shorts, the excessive current might blow a 'whisker' like a fuse. The silicon potting compound helps keep the by products from risking the other cells.
Battery cooling remains an open question. The silicon potting compound would inhibit heat transfer out the sides and even the top. So it may be the bottom of the cells are in a liquid coolant or touching a heat transfer plate.
