Identify this noise!
That sound is reminiscent of a brake shield metallic clang or hand brake holding a little and then releasing
Ok so I took the wheel off, inspected it. Reinstalled the wheel and torque to spec. Now the noise is gone. So it's the equivalent of "turn it off and turn it back on".
Now loosen the lug bolts and see if you used less force. Them torque em.
Should have torques them before doing anything to confirm or eliminate that as a possible cause
