navguy12
Situation: My wife's 2021 Kona EV. My yearly R&R of the winter tires with the all seasons; also my yearly lubrication of the brake calipers/caliper slider pins. I did a Homer whilst the rear left caliper was removed...I set the electric parking brake and naturally the piston hyper extended.
So, I manually screwed the piston back into the caliper, put everything back together and turned the car on and off several times...
...but I still have a Christmas tree full of brake system warning lamps that I don't know how to extinguish.
Also, I can hear the brake e-master cylinder clicking whenever I apply the brakes...
The car is drive-able, but brake regen is not being allowed, and I suspect the anti-lock system is also not being allowed.
I booked an appointment (for 1630 on 11 Apr 2023) at the local dealer; the service guy right away is saying it will probably need a new caliper.
Anyhow: does anyone here know of some magic trick (I don't have an OBD2 tool anymore) where I can reset the system (such as a series of brake pushes and signal stalk pushes) via some home-mechanic hack?
Thanks.
Thanks.
