Arctiic
DISCLAIMER: I will not be held liable for any damages or bricked head units as a result of any attempt to reproduce the following. Proceed at your own risk!
While messing around in ADB, I found where the screen resolution values are stored (allegedly) persistently:
- Connect to vehicle via ADB (default port 5555 for wireless)
- Enter `adb shell`
- `su`
- `cd /data/property`
- `busybox vi persist.sys.NV_DISPXRES`
- input `i`, then delete default value `800` and replace with `1600`
- input `ESC`, then `:x`, `ENTER`
- `busybox vi persist.sys.NV_DISPYRES`
- input `i`, then delete default value `480` and replace with `960`
- input `ESC`, then `:x', 'ENTER'
- `input keyevent 26` (screen should turn off)
- `input keyevent 26` (screen should turn back on)
- If above doesn't refresh, exit the shell terminal and try `adb reboot` (or just reboot the unit manually)
