How to change "Home" location?
Anyone know how to change the home location in the Cooper SE once it's set in the navigation map system. Mines been added with the wrong location but I can't find how to delete or change just this one location?
Yes, welcome @Nigel Warnes!
Digging around in my SE's menus, I found:
Navigation > Settings > Change home address
It also looks like you can change this at:
Communication > Contacts > Home contact
That seems far too simple and obvious. I looked for ages and couldn't
find how to change it. OK, off I go to the car to try again using both these.
Thank you for replying. It's good to know the forum works and is welcoming too
Welcome Nigel, This is where you will get real life answers to any EV questions, unfortunately the dealers do not want to invest time and money in training their staff regarding Electric Vehicles. This does not fill me with confidence should I have a technical issue with my car, my experience so far any call for support into the dealer is a waste of your time they know very little about the SE.
Update : Many thanks for the pointer on this. What I'd missed previously was when I viewed the contact how to edit the address using current location. I've now discovered clicking on the map I can initiate a save current location to contact Home and add as a 2nd address. It took me a while to discovered when on the first address I can use the Option button to bring up a delete button. Hey presto it works but what a phaf to simple add current location as home address.
Thanks again for your help.
