A simplified explanation provided by HKtech @ Ioniq 5 forum (thank you)
Boosting Voltage for 400V Chargers
Inverter as a Boost Converter:
In the event of a 400V DC fast charger, the E-GMP's inverter, which typically converts DC battery voltage to AC for the motor, assumes the role of a "boost converter."
Motor as a Reactor:
The vehicle's rear motor operates as a reactor within the boost converter circuit, facilitating the regulation of current flow.
Voltage Boosting:
Through this innovative utilization of the inverter and motor, the E-GMP platform effectively elevates the incoming 400V DC current to 800V DC.
Charging the Battery:
The amplified 800V current subsequently charges the 800V battery pack.
Trade-off for Using a 400V Charger:
While the E-GMP platform is compatible with 400V chargers, it is crucial to acknowledge that this process introduces an element of complexity and may result in a slight reduction in efficiency compared to direct 800V charging. The additional conversion step can potentially lead to some energy loss.
Motor as a Reactor:
Voltage Boosting:
