I can confirm (based on advice here on the forum) that there is an easy way to bypass Hondalink's odd behavior. Many have noted that Hondalink is not often properly updated and the dashboard can state an incorrect time and charge. You can refresh Hondalink again and again and it will still give readings that are often an hour old. The only way to fix it is to go to "locate my vehicle" and actually locate your vehicle. Once done, you go back to dashboard and you will now see the correct time and charge. I called Hondalink tech support about this and they acted as if they didn't know what I was taking about. It works every time.
