Lowell_Greenberg
The attached article is a technical summary of the Clarity PHEV powertrain and a performance comparison with Honda's older generation PHEV powertrain. Among other things it describes the rationale for liquid cooling, how effective cabin space utilization was achieved and why engine size could be reduced from 2 to 1.5 liters.
Also, figure 12, suggests that the upper end charge reserve is considerably less than the lower end. Assuming the line chart is drawn to scale, based on this, the question arises as to why Honda engineers designed it this way and whether it might be prudent for the user to "virtually" charge to 85%-90% to help preserve Lithium ion battery life.
Two things are frustrating: (1) Why there is no car indicator of real charge percentage and (2) Why the car/Hondalink app doesn't support charging to X percent. Of course assuming an 8.3% charge rate/hr and knowing the starting percent would allow you to approximate a desired virtual charge limit. But this is inconvienant and prone to error.
Nor do I think the question is academic. Charge levels above 85% to 90% may not ideal for a lithium ion battery, particularly under high ambiant temperatures and/or extended periods of sitting.
Finally, whatever the actual upper and lower reserve limits, continually draining the virtual battery percentage to the lower limit and charging to the maxium limit is probably not ideal either. Something like 85-90/25-30 seems best based on my prior reading and limited technical knowledge. Being more conservative than this may extend battery life, but compromise PHEV range so that the car can't be driven primarily on EV.View attachment Development of Electric Powertrain for CLARITY.pdf
Sent from my SM-G975U using Tapatalk
