Lars
Home made V to H
I used the same setup connecting my 1000W inverter to the 12V battery of my Prius with no problems. (The engine kicked in when needed, just had to keep the car out of the garage!)
However, when I connect the inverter to the my 2012 Kona Preferred the inverter shots down as soon as the HV battery kicks in to replenish the 12V car battery.
The inverter complains of HOV 'high input voltage'. The inverter's spec states maximum input voltage 14V. I measured the battery voltage while charging/replenishing and it flip flops between 14.7V 14.8V. (Not surprisingly the inverter kicks off immediately if the car in in Utility Mode.)
I tried an other inverter, with input voltage specked at Max15V it worked fine. So there is the solution. I wanted a 1500W inverter anyways.
However, 14.7/14.8V on the battery terminals while charging seems 'on the high side' to me. I would like to make sure that my car is the same as others on the road. Could someone please measure the charging voltage on their battery?
Thanks
Thanks
