What is the state of charge on your battery? A depleted battery seems to reduce HV mileage. Otherwise, yes, the faster you drive, the worse the EV range and the worse the HV mileage due to wind resistance.I noticed on the specs that the highway mpg is lower than city driving. Why? Is this due to stopping recharges the battery?
I’ve owned for a month and I’m on long road trip and just got 38 mpg on a whole tank in HV mode. Normally 45+
This is driving about 75mph
Thanks! Your experience provides another data point consistent with HV mileage being worse with a depleted battery. Except for the 100 mph portion. I don't think a full charge would have helped thereZero battery. That’s why I’m using HV![]()
I assume one factor, if not the major factor, is that wind resistance goes up exponentially as you drive faster. Therefore, to cover the same distance, the slower you go the less energy is burned for that trip in overcoming wind.
What you are describing is not the collision mitigation braking system (CMBS), it is the adaptive cruise control (ACC) system. The collision mitigating braking system will first warn you of an impending collision by flashing the "BRAKE" warning on the dash, followed by actually applying the brakes to prevent a collision if not done by the driver. The adaptive cruise control system will adjust the speed of the vehicle to prevent getting any closer to a preceding vehicle than whatever setting is selected, then returning to the speed set in the system prior to encountering a slower moving vehicle once clear of that obstacle.Something i have noticed that will also hurt the mpg is the collision mitigation doing moderate braking when i'm 200 ft behind a slower moving vehicle. Then when i change lanes it rapidly accerates to reach the set speed.
In a hybrid, you don't waste the kinetic energy of the vehicle when you stop, you convert it back to potential energy in the form of an increased charge on the battery.
I would suggest that the arguments being put forward about drag/wind resistance at highway speed are completely irrelevant. Those factors would be in play for any car, regardless of the type of propulsion system.
Most hybrid vehicles will get better mileage in city driving than in highway driving due to the energy recovery from the stop and go nature of city driving.
You're exaggerating how much energy a car with regenerative braking can recover. At best it's about 35% of the wasted energy.
Most of the excessive energy loss in a gasmobile in stop-and-go driving comes from idling and the fact that ICEngines are very inefficient when run at low RPMs. The latter is why the range extender in PHEVs is typically run unthrottled... wide open, at high RPMs, for maximum fuel efficiency.
Regenerative braking certainly does help with energy efficiency in PHEVs and BEVs, but it doesn't help that much compared to how much energy is lost by constantly accelerating and decelerating.
Not mere opinion here, but facts.
It's true that wind resistance causes drag to increase exponentially at higher speeds (and becomes quite significant above ~35 MPH) in all cars, not just PHEVs or just gasmobiles. But the question in the OP was why highway MPG is lower than city MPG for PHEVs such as the Clarity.
The most significant reason why that is, is increased drag from wind resistance at highway speed. It is said that at 55 MPH, a car spends fully half of its energy (and fuel) fighting wind resistance. At higher speeds, it's even worse. That's why MPG drops off so quickly at speeds higher than 55 MPH.
