aapitten
When I bought my PHEV in 2017 it was still fairly unclear if the PHEV got the heads-up or not (and auto high-beams... and rain-sensing wipers...) I found out very quickly it didn't have any of those.
(Despite Honda even getting it wrong on their site! https://www.insideevsforum.com/community/index.php?threads/autodimming-high-beam-headlights.679/)
I've always wondered if it would be possible to retrofit a HUD from the Fuel Cell. I figure the obvious things that would need answered:
1) Do the cars share the same dash? If so, perhaps the spot for the projector just has a 'plug' in it.
2) Do the cars share the same windshield (for the reflective coating)
3) Is the appropriate wiring in place to 'plug and play'
4) Is the programming/ computer module in place (or easily addable) to control everything
#1-2 are pretty easy to check by comparing part numbers, #3 may be a bit harder, but not impossible to figure out. #4 would basically be impossible to know unless you just try it.
Curious if anyone has ever investigated this? The parts are available (though quite expensive at over $3k...) 78200-TRT-A01
