Gatsby got new shoes!
The 'Kooks look almost stretched. Nice effect. I wonder what the efficiency hit is with the (slight) added weight, rolling resistance, and increased frontal area.
I’m confident it won’t be a massive hit. The overall diameter is a bit larger so the rpms at any given cruising speed will be about 3% lower, that’s the one thing working to my advantage. I picked these tires in particular because they were offered on SEs from the factory, figured that was the safest way I could find a parity with the stock rubber as pertains to noise and rolling resistance since these were offered on cars that had the same stated range. Scientific? Not in the least… but I don’t have the time or bandwidth to conduct the kind of research necessary to do better. I’m perfectly satisfied with hedging my bet on “OE or similar equipment”.
I’ll be sure to report back after I’ve got a few commutes under my belt. Standard drive to or from work has reliably used 10% of the battery over the past couple months so I think I have a decent baseline in addition to my onboard mi/kWh readings.
