Charles Gibbs
Good day all From Namibia.
I would like to ask if there is anyone that would be able to help me with issues I am having
on a self built Fiat Uno also known as a 146 I think in USA and EU.
This car was converted in 2006 and was done by a German gentleman here in Namibia.
When I got the car it had an old VPA inverter in it that needed replacing.
The gentleman had already some years back acquired and MES DEA SA Tim400.
He was not able to work on the car any further as he got sick and so I was able to buy it
from him.
The motor is also of German origin can't remember the name now, it is an ac induction motor and runs though a small differential, presumably the motor is a 30KW (I know it is small) on the name plate is written the following.
100V
200Hz
86 Amps
6000 Rpm
The Tim is 80 -400 VDC 280A capable.
I have a 60Ah 180 VDC CALB cell pack.....
Please note that when it comes to EV cars I am a complete noob, I have built a few ebikes that
are high powered so am familiar with ev tech.
BUT the parameters on this inverter are not english...... They are in technician.....
And I am not there yet...
Ok, so, I built everything in and got things running.
The controller has an auto tune function in it, I just had
to enter in a few easy things of the motor and battery pack:
Motor voltage: 100V
Motor Amps Nom: 86A
Motor Poles: 4
Number of absolute encoders: 2
Number of motor pulses /RPM: 25
And then battery pack stats for over and under voltage.
The problem:
When I am driving and reach an almost no load speed the motor surges and slows and surges and slows causing the car to buck back and forth until I either put my foot down further onto
the accelerator or let off. The Ammeter needle drops to zero and goes back up in sympathy with the motor. it can be at 30 kmh or 60 kmh does not matter, as soon as there is very little load on the motor this happens.
When I come to a complete stop, I can sometimes feel the motor rocking and if I put the laptop onto the controller the RPM meter confirms this by going to 50 and then -50 RPM, if I take my foot off the brake and pull up the hand brake it'll stop.
If I disable the regen then it does not do it.
Now, if the manual did not describe the setting in a plain readable language I left it alone
as I am in way over my head when it comes to ev car inverters......
I do hope that someone will be able to advise me in my predicament.
Thank you in advance
Charles Gibbs
from him.
100V
200Hz
86 Amps
6000 Rpm
Motor voltage: 100V
Motor Amps Nom: 86A
Motor Poles: 4
The problem:
Charles Gibbs
