The camera is built in to the mirror itself. I believe it's on the driver side of the back of mirror.I hang my handicap hang tag from my mirror and it does not interfere with the Honda Sense camera mounted directly to the windshield. Hope this helps. What camera do you have on the back of your rear view mirror?
Will the ezpass register if it's attached on the windshield black dot grid or does it need to be just below the dots? Thanks!The sensor on the driver side, back of the mirror is a light sensor for auto-dimming mirror and not the camera. You can put the ezpass above the black boxy thing behind the mirror that is glued to the windshield
to the right of the camera (so on passenger side)? We tried holding it up today in the black dot area and it didn't register, but there may be a problem with that transponder. thanks!I have it on the black dots. From the driver seat, I can see the word "E-Z Pass". That's how high I got mine. No issue crawling through the toll booth at HT, LT, NJTP.
That’s correct. But they are ridiculous now because they are anachronisms. They are a 1987 technology, still in use 31 years later for no good reason. My first Sony Walkman cassette player was a revelation, but I would look pretty ridiculous sporting one today.
I will attach a picture tonight .to the right of the camera (so on passenger side)? We tried holding it up today in the black dot area and it didn't register, but there may be a problem with that transponder. thanks!
True about that. I'm not thrilled about the glue. They're sending me a new transponder & I may see if holding it up works. E-Z Pass assured me that if the transponder doesn't read they'll go by my plate AND that discounts still apply. Hopefully the latter is true.I don't like sticking things to the windshield, and afraid the black dots will get damaged if I try to remove the 3m glue. I prefer suction cups, but they don't work on the black dots.
The 18 Ody for example has black dots but are part of the windshield so suction cups works perfectly.
