I happily rolled up to an EVGO charger at a Massachusetts Turnpike service area this afternoon. After authorizing with a credit card, the cable unlocked. The plug had two sections: a circular upper portion which seemed like a perfect match for the Clarity socket, and an oval lower portion apparently made for DC charging. I was unable to plug the cable into the Clarity, because that lower section bumped into the plastic at the bottom of the socket.
Is that as it should be, i.e. is this just a design problem we have to live with, or is there some workaround, such as an adaptor?
PS: The charger had a second cable labeled chademo, which I’m pretty sure is complete incompatible with the Clarity.
