Patrick drumm
Will 195/55r16 and 205/55r16 fit the se’s 16in wheels. I am curious about Erange ev tires and they seem to have the 205/55r16
hiWill 195/55r16 and 205/55r16 fit the se’s 16in wheels. I am curious about Erange ev tires and they seem to have the 205/55r16
5mm may do it 15mm would definitely I'm sure..a forum member has done 15mm spaces on all 4 and reported all is wellI would consider spacers if I could get away with maybe 10 mm. Any idea how big a spacer you would need to clear the shocks
well we all now have nothing to fearI am running 15mm/20mm spacers on the front and rear and am lowered.
Tires are first and foremost safety equipment, and I'm real suspicious of any new brand that builds their identity around rolling resistance instead.I am curious about Erange ev tires...
With the spacers and lowering I am finding I am getting slightly better range. Where I got 5.3mi/kWh to 5.9mi/kWhAdd tires that allegedly give more range, but add spacers to push the wheels/tires further into the airflow possibly decreasing range.
Adds up!
Wow, that's great range. How slowly do you drive?With the spacers and lowering I am finding I am getting slightly better range. Where I got 5.3mi/kWh to 5.9mi/kWh
