This may be well known, but I’ve found a fairly reliable way to engage Engine Driving Mode without resorting to the HV reset method, which results in a continuous reduction of the SOC set point with each implementation.
Once HV is activated, at speeds above 45mph, let off the accelerator pedal until the power meter dips into regen. Gently press the accelerator pedal and see if EDM has engaged. If not, rinse and repeat. For some reason it seems to require the car to be in HV for a few minutes before this technique works.
It works well on flat terrain. It will not work well if aggressive acceleration is demanded or on an incline where more power is required to maintain speed or accelerate. EDM will remain engaged under relatively low power demand situations, such as maintaining a set speed or very gentle accelerations. Moderate to aggressive acceleration will cause EDM to disengage.
