ClarityBill
I have been wondering if the percentage of braking power provided by regenerative braking is very low.
The friction brakes seem to activate immediately with brake pedal motion.
The transition from friction brakes to regen is ‘unbelievably’ smooth, so I tend to believe there is no transition.
It would appear that friction brakes are the primary brake. The regeneration is also there.
The output from a rare-earth generator (traction motor acting as a generator), is directly proportional to the rpm. What method would be possible for the brake pedal to increase the regeneration smoothly with decreasing rpm?
The paddles can increase regeneration in step fashion. The stator on the traction motor could be divided into four coil sections. The first section is always active, the paddles then apply the three additional sections. If no regen paddle is used, the regen would be very small because only one quarter of the coils are active.
Even with full 4-chevron regeneration, the car does not slow as fast as ‘normal’ friction braking.
The power gauge has been assumed to show actual regeneration, but when driving the car, it seems to include the power from the engine in engine drive mode: It is not a purely electrical power meter. It could include the power going to the friction brakes.
Maybe Honda does not display regeneration achieved, because it would be small.
