The Leaf e-pedal works very well for driving. The interaction between regenerative and friction braking is practically seamless. I have enjoyed the one pedal driving very much.
Here's the glitch. When the e-pedal is ON the slightest amount of regen causes the brake lights to come on. So when you're in heavy traffic especially on the freeway the variance in the speed of traffic flow means that your brake lights are constantly flashing on and off. This has proved to be extremely annoying to the drivers behind you. Some that follow a little closer than they should think you're trying to brake check them and will pass agressively and cut in front.
So as much as I have enjoyed using it I'm keeping it OFF most of the time now. Really Nissan, the brake lights shouldn't flash until an appropriate rate of de-acceleration has been reached.
