Cruise Control Question
  • Thread starter Thread starter Joev
  • Replies Replies 4
Joev
Hello All!
With the cruise control on and set to a speed to hold then disengaged (but still on), does the display for the cruise control still display the set speed that was previously set?
I thought mine use to but now I don't see it anymore.
Could another Kona owner let me know If I'm missing something or perhaps I changed a setting that affected it?
Thanks All!
Love the knowledge/experiences shared here!
Depending on what trim level you have. It always displays it in the dashboard in the middle top. However if you have the ultimate trim it seems like it only displays it initially in the HUD. It then disappears there.
Hello All!
Thanks All!
I believe the set speed disappears when you reach that speed and maybe also if you exceed it.
When you set it the set point is displayed above the speedo. when you brake etc. the Display is still there but not the speed when you resume after braking the set speed returns again … You need to turn off the cruise to disengage it all.
Another thing is if you tap the res button while cruising it increases by one Km if you hold the res. button it increases by 10KMs
