Just a reminder, with the cool weather, it is time to top off the tires. It is 58 F (14 C) in Huntsville AL which means all the tires will be about 3-5 psi low and need to be brought up.
My practice is to set them to the maximum sidewall pressure. Decades of Prius driving confirms: (1) better steering; (2) better water on road handling, and; (3) longest life on the tires.
Modern radial tires have a belt that prevents abnormal wear as LONG as the alignment is checked yearly. On caution, after an alignment, the tire shop will be set the tires to the door jam pressure. So I borrow their hose and use my tire gauge to air them up again.
