su_A_ve
Noticed yesterday the 12v power socket under the console died.
I had a dual port Anker USB plug and noticed it wasn't working, and neither was my dash cam. The rear socket is working fine. Tested the USB plug in the rear power and it is working.
Found the listing of the fuses and it seems it is fuse C10 20A. Last time I replaced a fuse in a car was over 30 years ago.. Here comes YouTube - how to test a car fuse with a multimeter...
Car is on warranty but I assume I should take the camera (and wire routing out and then have them check the fuse and/or socket)?
Note that I've never plug/unplug the USB plug. It is a 2 port plug and once in a blue moon I would use the 2nd port. The camera is the one always in use otherwise.
Have not tested the camera but doubt this could have caused a short or something - if anything, the plug would have gotten damaged and it's not the case.
Suggestions?
Suggestions?
