Does anyone have any concrete information on whether 16" wheels will fit on the Niro EV? Looking at the front caliper clearance, it seems like there's enough room. Keep in mind that there has to be enough room for wheel balancing weights to also clear since those are taped to the inside as near to the wheel front face as possible.
The upside is a bump in efficiency and also a smoother ride since the 16" tires will have a larger sidewall. The tire size I would use would be 205/65 which comes within 1% of the same diameter of the factory 215/55 tires. Thoughts?
