I have a 2015 MINI Cooper hardtop, which introduced me to the coding (should be called changing parameters to be more precise). Basically you use ESYS to change some values and write that in your 10 or so ECUs. You can change things like getting rid of the annoying “do you agree?” disclaimer prompts in the start of your car, change some behaviors like auto engine on/off, climate control AC auto on/off, LED bulb check, etc.
There’s also a program called Reingold which has a bunch of tear down and service instructions meant for the service department.
Is there such a thing on Honda Clarity?
