-QUOTE="Sandroad, post: 46111, member: 5847"]The 18-089 update required a part, a CPU assembly 06999 that is part number 06796-TRW-A00. Is that part number listed on your repair order?[/QUOTE]
That part number is listed in the first part of the order. But which update is it for, the Climate control unit or the A/C control unit or are they the same thing? The reason I'm confused is that the order says "correction" and then lists A/C control unit. It is probably just semantics but I'm curious. Thanks.
Tim
