Ray B
My wife recently received her '22 Rav4 Prime SE and I've had a couple of opportunities to drive it after about 4 years driving my 2018 base Clarity PHEV. Just a few quick observations on differences - mostly the driving and convenience features ... (I'm a noob to the R4P so some of these may be moot if I research it a little more)
On the plus side the R4P has:
- Regen is only through the brake pedal - no paddles. It's fine, but I just like to drive with the paddles doing most of my braking around the local roads
- Pedestrian 'music' warning is much more obnoxious, and persists up to ~22 mph. Even plays when the car is 100% stopped at a stop light
- The cruise control needs to be turned on every time you want to use it after the car has been shut down. It shuts it off when the car is 'rebooted'
- ACC following distance defaults to 3 bars and it doesn't remember the setting when rebooted. So when I want to use ACC in the R4P I have to switch it on, set my speed and change my following distance, rather than just hitting 'Set' in the Clarity
- The engine is quiet, but a little more noticeable than the Clarity in HV mode around town probably more more vibration than outright noise.
- The overall ride is obviously much different and not 1:1 comparable, but overall the Clarity in EV is smoother and quieter, as you would expect.
- The R4P dash display is very busy but paradoxically has less detail than the Clarity. Some examples... EV range estimate is in full digits (no decimals = no big deal for me), EV battery gauge is an analog dial, but there are no gradations, the power meter is off to the left and not in the line of sight which would be better IMHO, overall more info clutter when using the range estimate screen option. Here's an example image from https://everydaytoyota.ca/2022-toyota-rav4-interior/
- There is no warning/control for triggering the engine in contrast to the detent on the accelerator on the Clarity in ECO-EV mode; though I drive gently enough that it has not triggered
- I haven't been able to figure out how to decrease the volume on Waze or Google Maps in Android Auto. When turning the volume knob or buttons it activates the music to start playing instead of changing the volume as it says it should; the Clarity responds appropriately, so I doubt it is an AA issue
- My Clarity has three garage door buttons, and I haven't found such a thing built into the Rav4 (to my surprise)
- The Toyota app only seems to be able to register with one owner. Also the app doesn't provide the state of charge for the EV battery. Only tire pressures are the only sensors data available from what I can see.
- From what I can tell, there is no option to have the R4P lock automatically when I walk away with the key, as I can with the Clarity. I don't see that setting in the options. But touching the door handle does unlock the doors.
- The Rav4P came with 8 manuals/books/guides (!), including a full size manual. So the glove box is already full
But many of the above mentioned things are not covered from what I can tell though I've only browsed it so far
- real windshield wipers
- a full sized gas tank
- a volume knob
- a tuning knob
- a backup camera that out-performs a potato
- no 'wings' to break a knee on
- With the 2.5L engine, I doubt the R4P will struggle up long hills at 0EV (when not thinking ahead), at least to the degree that the Clarity does
