Dan Albrich
So my Clarity hasn't usually had 'normal' EV range compared with others-- on the low side.
My estimated range is now down to 28 miles, and it will go down further (we're not very cold yet here in Oregon).
So what I notice, I get in my car and I'm cold. If it's say 43F outside, and I turn the heat to 70F with the dial, warm air does not come out of my vents. Is this sort of like a heat pump where it warms super-slow? I find to get noticibly warm air from the vents I select 80, or just spin the dial to HI which works. I can get warm/hot air, but if and only if I do high temp on the dial.
So just curious what others experience is. Maybe the reason my EV range is lower than usual is that I simply must 'goose' the heat to get heat, and maybe that's not normal.
-Dan
-Dan
