Just the opposite finding by me. I recently drove a 100 mile section of US 127 in northern TN and found the cornering fun and responsive. I don't know the actual center of gravity of this car but I would imagine (because of the battery) that it is a bit lower than your typical ICE luxury car that sells for less than $35,000.Is anyone else finding the Clarity handling a bit more ponderous/heavy as they drive the car over time? I didn't notice it much at first, but it definitely comes out more on winding roads. That was one of the issues noted in several reviews.
To what are you comparing the Clarity, a BMW 5 Series? Are there other 4,059-lb family cars that handle as well on tires not designed for handling?Is anyone else finding the Clarity handling a bit more ponderous/heavy as they drive the car over time? I didn't notice it much at first, but it definitely comes out more on winding roads. That was one of the issues noted in several reviews.
There is no doubt Honda engineers could have tuned the Clarity suspension to be sporty like the current Accord Sport or Touring, which have gotten rave reviews for handling. The issue is compromise. In order to get the longest EV range and HV mileage, they installed low resistance green tires, which by their very nature are not "sticky". If they tuned the suspension for sport, some drivers might push their Claritys, which would be a disaster because the reviews indicate that the Michelin Energy Saver tires installed have a tendency to lose grip abruptly. That is, you can take a curve feeling pretty good but the tires' poor grip can cause you to lose control. Instead, Honda engineered a sophisticated suspension (struts up front and multi-link rear) that favors a luxurious ride. In doing so, drivers are less likely to drive the Clarity like a sports car. What many of us have discovered is that the Clarity actually handles surprisingly well in the twisties, which is unexpected for such a cushy suspension. That could be due to the lower center of gravity and better weight distribution compared to typical FWD family cars. The steering, which is quick and precise like a sports car, also helps. For that reason, installing high performance A/S tires makes sense if you want to improve the handling because, unlike floaty Buicks and Cadillacs of old, the suspension can make use of them. You'll just lose some EV range and HV mileage.To what are you comparing the Clarity, a BMW 5 Series? Are there other 4,059-lb family cars that handle as well on tires not designed for handling?
