I don’t know if I’m having bad luck or what but I’ve had my clarity broken into three times in the last year. It’s happening in the Angeles national forest so it’s a bit out there but close enough to civilization to have issues. But I’ve been going to the Angeles for many years before I got my clarity and didn’t have even one break-in.
It looks like they just shove a screwdriver into the lock and open the door. After that, you can still lock the door but it’s very easy to open with any screwdriver-shaped object and it doesn’t make the second beep when it locks.
So are Clarities especially easy to break into or am I just having bad luck?
It costs $500 to fix the lock at the dealer so this time I was just going to not fix it. It locks so you would actually need to have intent to break in, so I figure it’s basically the same situation I’m in now.
I was also considering putting some jb weld into the lock, but then I wouldn’t be able to use it if I needed to. Not sure what to do. Any suggestions are appreciated!
