CyberDyneSystems
I am going to try to write this as objectively as I can, but it won't be easy. I really liked my Prius Prime, but the Clarity ticks so many more boxes, and is such an upgrade, it is hard not to gush uncontrollably like a co-ed with Harrison Ford as a professor in "Raiders".
I'll start with the short list, of what the Prius does better than the Clarity, because it does have some objective and subjective advantages.
- Autopilot/Cruise control: Prius Primes' "auto pilot" braking and cruise control is vastly smoother in use. In the Prime, it slowed down as I approached oncoming vehicles gently, then it would begin to roll again gradually, all as if a conscientious hybrid owner was driving and applying the brakes and accelerator. In the Clarity this is not smooth, It's as if it's being driven by a new teenage male driver, herky jerky on the brake and accelerator.
- MPG: Highest rated Hybrid mode MPG.
- Range: Longer combined range (like nearly 600miles vs 375 or so.)
- Hatchback: Subjective of course, but there are times (and people ) where the preference is for the hatchback. This "advantage" is mitigated by the fact that the Clarity actually has very good trunk space, so it really is a sketchy "advantage" Perfect world would be if the Clarity hinged above the rear windshield as a hatchback. In the Prime I was able to use it to carry a LOT of 8' lumber by folding seats down.
- Information: The Prius Primes multitude of information display settings are not only prolific, but easily and massively customize-able. One can set the various LCDs to provide exactly the info you want all the time. Again, this is subjective, and again mitigated by the fact that the Clarity's display is much more elegant, looks more like a car, is positioned in the right place, and just overall more pleasing and less "weird". Perfect world would be if the Clarity allowed us to customize it's display more, with at least two separate sections.
- Mag Wheels: Remove the Primes ugly arse plastic hubcaps, and you get a VERY stylish set of alloy rims. For Free! Removing the plastic from the Clarity reveals even more ugliness!
- Center Console: Prime has larger storage in center console.
- Volume Knob: Nothing else need be said.
Okay, now that's out of the way, let's move on to the Clarity's advantages.
- Longer Battery Range: this was THE reason I was unsatisfied with my Prime, and once the Clarity was announced I started plotting the trade in. If not for this, I never would have even looked at the Clarity. I am glad I did!
- Seating: Clarity Seats 5 comfortably. Of course the Prime can only seat 4. No you can't even fake it,. it just can't seat 5.
- Trunk Space: Oh you want truck space? Well, then don't bother with the Prime. The Clarity? It's got it in spades. Where the heck did they put all those batteries? The Clarity not only has ample trunk space, again unlike the Prime, it also has a sizeable secret hidy-hole for other uses*. (*see next entry) This is where the Prime designers really show the lack of thought that went into making the Prius a plug in with EV range. No attempt to fit the (minimal) extra batteries in a way that was unobtrusive. No they took your trunk space and gave it to the batteries. You give up all that space and only get 17-30 miles (depending on season/temp) of battery only range.
- Audio Upgrade-ability: I am a bit of a audio junky. I've put very good to "high end" audio systems in the vast majority of the cars I've owned, starting all the way back in the 1980's running audio cassettes. For the two years I drove the Prime, I was plotting HOW I would shoehorn a good system into the Prime without compromising the limited storage space even further. I never did it. The Clarity has this wonderful space below the trunk floor where a jack and other tools might go (mine came with none of those?) Instead, it's housing the DSP, and a pair of amps to power the new door and column mounted speakers, and the removable sub-woofer that fits in yet another "part" of the trunk that isn't the main compartment. Combine all that with the Claritys' amazing front tweeter placement and you are set for a VERY nice platform for an audio upgrade!
- Styling: Prime looks fine, Certainly better than the standard Prius. But it still looks quite a bit "eco/green". Clarity just looks good. If you can accept the aerodynamic throwback to the first plug in electric cars' rear wheel covers,. then it's a damn fine looking car. The front end is simply gorgeous IMHO, with THE. BEST. (full stop) driving lights in existence! It's great looking from any angle with the possible exception of the rear 3/4 view, (but to me the wheel wells are not an issue.)
- Climate Control: AC is faster, better, settings are better/more accurate (I set mine between 70-72 and forget it) I have yet to need to try heat, but I can tell you that vs. my previous Toyota Tacoma, the Prius Primes' lack of ability to comfortably keep me warm on a half hour commute was legendary. For two winters I wore a "lap blanket" because my legs would ALWAYS be cold, regardless of what the Prime's settings were. I am a cold blooded red headed viking that is always too hot. Not in my Prime in Winter! I have high hopes that the Claritys' heat will equal it's AC.
- Comfort: Clarity is more comfortable. I have the base model.
- Quiet: An even quieter ride than the Prime, more insulated.
- Ride: So smooth. It's like a true luxury car. You'd need to move up to Lexus to get something this smooth in a Toyota.
In short, right now I am in honey moon mode. This is the best car I've owned since my 1969 Cadillac I owned in the late 1980s. It is the most comfortable, quiet, stylish luxurious ride. I am really looking forward to the next year commuting to work.
Thanks for all your insight (unintended) and help getting to upgrade to the Clarity. I am having a blast!
(photos of Audio install to come, maybe in another thread)
Jake
Jake
