I am new on the forum. Bear with me if this has been answered before but I cannot find a good answer.
I am getting my new Kona delivered end of this week.
I have one concern. The tires that the car is delivered with. I expect the car to be delivered with Nexen n’fera SU1 tires.
In reviews as well as my own test drive it comes across that the car has a tendency to spin it’s wheels. Especially in wet weather.
Delivering almost 300 lbs ft of torque from standstill onwards will be challenging for any fwd car. Trying to do it with sub-par tires like the factory fitted Nexen tires is clearly proving impossible in some situations (not just from standstill).
So consequently my question is:
- what are the experiences mounting other tires that forum members have?
- are there any particular experiences?
- what is the effect in range that members have seen by mounting different types of tires?
I am considering changing the tires straight away to one of the following:
- Michelin Pilot Sport 4 - I would expect grip issues to be solved. These should be nearly as good as it gets. Ride comfort should be ok. Key concerns are efficiency/range implications and noise levels. Any experience?
- Michelin Primacy 4 - I would expect efficiency to be better. Noice to be almost unchanged. Comfort should see limited impact. There should be some grip improvement but not sure whether it is enough to rectify the grip issue. Any experience? (I believe the car will be delivered with these from q2 2020 onwards, but unlikely for my car).
- Continental Premium Contact 6 - probably somewhere between the above two.
Any thoughts? Any alternatives? I am not too concerned about a potential price difference. I want to achieve a ride that can use the torque without spinning the wheels at odd times and I would like to minimise additional noise and energy consumption.
